Cayenne calipers
  • Jay
    • Jul 2004
    • 599
    Cayenne calipers
    Does anyone know if cayenne red brembo calipers mount the same as 'big reds'? as I have the option to buy these new/cheap!!
    James
  • Jay
    • Jul 2004
    • 599
    Also are 'big reds' radially mounted or axially??
    James[/QUOTE]
    • s2driveruk
      • 12696
      I think they are a radial mount and heeeeavy from what i remember.
      Would be interesting if they bolted straight into the existing S2 holes on the strut and everything lines up but i guess that would be too much of a coincidence
      David
      1992 3b S2 Coupe
      • S2 Ant
        • 3682
        I would have thought you would need totally different mounting brackets as they are monster 6 pot calipers.
        With the correct carrier they would fit and have been discussed before if you have a search thru this section
        Ant
        2011 Kawasaki Z1000
        • Lee
          • 1512
          Cayenne calipers are massive and I doubt the bolt pitch is the same as any other caliper...wouldn't make sense structurally to have a small pitch on such a large caliper. Didn't Jeffer or Cees use this caliper? If they did, their brackets looked much larger than big reds. Not a brembo person myself...as me anything about the APs and you will get data! LOL!
          Anything can be made to fit.
          If you are getting them cheap and want to make a few extra quid just for handling, let me know how much you want for them. I currently have a few sets of 6pot APs waiting for collection but I can always look at the dark side.
          Designun Limited....
          • 91_S2
            • 612
            James
            [/QUOTE]
            Radial
            • Jay
              • Jul 2004
              • 599
              Cheers Lee:-
              Part numbers as on each caliper:-
              Left: 207673 03 2 & 4L1513
              Right: 20767304 5 A & 4L0813
              They are 4 pot not 6 and the mounting bolts are axial in direction.
              I may yet just 'handle' these and your conversion is on the want list (front and rear) just spending a fortune on building up my spare engine at the mo.
              prob see you at the B'church gargage meet (would like a spin in yours if pos?? )
              Jay
              • Jeffer
                • 2057
                These are 8-pots from a AMG SL. Also; Cayenne calipers are side bolted, these are bolted from the top. Disks are from a RS4
                RS2 Black - stock 315 HP
                RS2 RS blau - stock 315 HP
                Sport Quattro - 1005 HP
                High Octane website
                • Jeffer
                  • 2057
                  btw; those are 18" wheels
                  High Octane website
                  • S2 Ant
                    • 3682
                    That is one hell of a custom bracket!!
                    Ant
                    2011 Kawasaki Z1000
                    • NoNonsense
                      Forum Sponsor
                      • Apr 2004
                      • 673
                      David
                      If only we could be so lucky! Believe it or not, though, the B5 S4 can bolt these calipers right in...but you'll still need custom rotors and hats. There is a tuning company here in the US that does this upgrade for the B5 S4. Any other car would need a bracket similar to the one found in the lower right of this pic...
                      Joe "NoNonsense"
                      axis motorsport
                      joe@axismotorsport.com
                      "At the end of the game, the king and the pawn go back in the same box."
                      • s2driveruk
                        • 12696
                        heh Joe...as i thought, no hope with an s2 I loooove those calipers behind the RS4...i'd have the black or silver though i think.
                        1992 3b S2 Coupe
                        • NoNonsense
                          Forum Sponsor
                          • Apr 2004
                          • 673
                          agreed...i like understatement. i have got black calipers now...and I wouldn't have it any other way!
                          Joe "NoNonsense"
                          axis motorsport
                          • Alistair C
                            • 693
                            Cheers Lee:-
                            Jay - you sure they are Cayenne front calipers:
                            from my extensive caliper photo library (courtesy largely of ebay.de), I believe cayennes have 6 pot front calipers and 4 pot rears. Again, like the other cars, the rear calipers have small pistons.
                            Fronts:
                            Rears:
                            HTH
                            • karlblues2
                              • Jul 2004
                              • 402
                              • Home: England Current: Australia
                              Yep. that's my understanding too. The Cayenne S and Turbo both, I believe have 6 pot Brembos at the front. I'm using the ones off a 996 GT3 Carrera Cup Car, which apparently are slightly smaller and lighter??? APR www.goapr.com is the company in the US that is doing the Brembo conversion on B5 and B6 model A4's. they use cayenne silver 6 pots. My brakes require custom brackets and are being built as I type this I will post piccys and dimensions etc as soon as I can. BTW, mine will be mounted over 362mm AP racing discs, and using the standard Porsche 996 GT3 Pagid pads (cut down slightly from the top to ensure proper coverage)
                              Oct 93 build MY 94 ABY Kingfisher Blue Audi S2 with MD147 turbo :mischeif:u SOLD
                              Audi 90 Quattro 20V 1989 7A
                              Audi TTRS 2010 APR stage 2 +
                              Triumph 675 Street Triple R
