Got remapped and need more brakes - damn !
  • Got remapped and need more brakes - damn !
    Chaps..
    Think I need new brakes ...
    The car had a recent remap and have had a few brown trouser moments, more due to the fact that the discs and pads are a bit worn.... but I am using this as the excuse for "a bit more brakes"
    I have already upgraded to gt3 4 pot calipers with 965 351 046 discs (322 x 22)... All fitted perfectly.
    My new calipers are GT3 6 pots (996.351.432.30). I measured them up and they appear to be the same bolt fixing points and width as the 4 pot, just longer.. so my custom brackets will still do the job. Clearance under my 18" Cup Wheels will not be a problem.
    So here is where I need some expert advice.
    - Anyone done this before and can I go for bigger discs to get more brake torque ?
    - I am planning to use 350 x 34 discs but the center line of the disc needs to be the same as the existing 322 x 22 discs. From my calculations I need a top of bell to center of disc dimension of 61mm, 1mm less than the 322 x 32 disc. So, Can anyone tell me if there is a standard porsche disc which will fit or am I better to have custom bells and rotors made ?
    - If I go for the custom bell / rotor route, where can I get them and what would be the approx cost ? Is floating better than solid for the road ?
    - The Calipers need to be fitted with new seals, is there a rebuild kit available for these calipers? Where is the best place to buy ??
    - What pads do I need to order, the calipers came without them ?
    Sorry for all the questions but you could save me a lot of time (and money) if I can avoid the trial and error approach to this problem...
    Appreciate any advice you can give..
    Paul
    RS2 Brakes
    Give Berlyn services a call 07771 814334
    They specialise is Porsche/Brembo brake parts,very helpful and good prices too.
    Andy
    PS,I've also sent you a PM
      Pads are not cheap. Red stuff worked well for me.
      Brackets i think bambridge
        in a very short answer yes it has been done before....
        I run Phaeton W12 disc and bell assembly and they are about £340 for a pair
        seal kits, try a brembo dealer or porsche....mine are literally brand new
        as for pads, I'm running DS2500 from curcuit supplies, speak to Tim as he sorted mine out and cost a year or so ago £230....
        HTH
        Mike
