noisy brakes
  • nip
    • Apr 2006
    • 1786
    • Home: United Kingdom Current: Abu Dhabi
    noisy brakes
    have found a noisy brake squeak its the same as this vid , the vid is the same as my problem has anyone had this problem?
  • nip
    • Apr 2006
    • 1786
    forgot to add, there Porsche big reds calipers
    • Rusty
      • 18953
      Are you running the anti rattle shims?
      • RS2junkie
        • Mar 2011
        • 409
        • Home: Ireland Current: Bahrain
        Some possibilities,
        Are the pads running smoothly on the stainless guides ? If you take out the pads, look for signs of contact between the steel pad plate and the slider at each end of the pad ...
        The old style big reds can suffer from aluminum corrosion behind the slide plates, not easy to cure completely, this is why Porsche went to monoblock calipers...
        Interesting to find out what it is ?
        • nip
          • Apr 2006
          • 1786
          Yep andy i am
          • nip
            • Apr 2006
            • 1786
            Originally posted by RS2junkie
            Some possibilities,
            Cheers im gonna take them apart saturaday il keep you posted
            • Rikki Kitto
              • Feb 2010
              • 6276
              Mine make noises too so watching with interest
              • nip
                • Apr 2006
                • 1786
                Forgot to update I took the brakes apart cleaned all parts up re fitted working fine now no more noises hope it helps
                • 20vturbour
                  • Apr 2006
                  • 121
                  '05 A6 3.0 S-LINE TDI- AKOYA SILVER SOLD
                  '98 S4 B5 MRC- MINGE BLUE SOLD
                  '85 URQ RS2 SPEC- TORNADO RED
                  '95 RS2- RS BLUE
                  • nip
                    • Apr 2006
                    • 1786
                    Take the pads out I sprayed everything in brake cleaner re greased the shims worked perfect for me
