rs2 big brakes, discs??
  • nicksonmsport
    • Mar 2014
    • 380
    I know there are a few stickys on this subject, I have read them, and still have an unanswered question.
    it seems the Porsche 965 front discs will fit fine just not fully floating as original.
    the problem is the rears. I would like drilled if possible. it seems the rears from Porsche 965 are the right size and drilled, but is the hat height correct?
    part number 96535204100. they look shallow compared to some of the other options which are 20mm out hat height.
    can anyone confirm if Porsche 965 (964 turbo) are correct for the rear, and if not, options for the correct rear disc with correct hat height.
    many thanks
    nick
  • RS2junkie
    • Mar 2011
    • 409
    • Home: Ireland Current: Bahrain
    Nick,
    I will be at home in a short while and I can give you some part numbers of porsche 928 discs (drilled) which will work. I have boxter s monoblocks on the back of my RS2 and it uses the same dics.
    Just upgrading to 6 pot fronts so on the look out for matching discs.
    Stand by...
    PAUL
      Rear of RS2 is 928, zimmerman do drilled rears, I ran porsche boxster rear calipers and GT3 fronts. Every other porsche has a different hat height
      • RS2junkie
        • Mar 2011
        • 409
        Nick,
        Stand by...
        PAUL
        • RS2junkie
          • Mar 2011
          • 409
          Nick,
          This is what I have on my RS2 now.. hope it helps
          Paul
          BRAKES
          Front
          911 GT3 Monoblock Calipers 996.351.429.10 / 996.351.430.10
          Porsche 911 Turbo S Discs (965) 965.351.045.00 / 965.351.046.00
          Pads 996.351.940.12
          Caliper Support Brackets Custom
          Rear
          Boxter S Rear Monoblock Calipers 996 352 421
          Porsche 928 S4 Drilled & Ventilated 951 352 041 01
          Pads 999 073 40201
          Handbrake Shoes 996 352 993 01/1
          • nicksonmsport
            • Mar 2014
            • 380
            that's great cheers, will those discs work as bolt on option with my big red fronts, and std rear calipers? I know the fronts are right, but its the rear hat height im trying to make sure are right with the 928 discs and my std calipers on the rear.
            I can get fronts no issue from ecp, if I cant get the rears, wheres best to find them? design 911 sell these which look right to me
            http://www.design911.co.uk/fu/prod72...28S4---928GTS/
            but im sure I read somewhere this part number was not the correct hat height??
            many thanks
            nick
            • RS2junkie
              • Mar 2011
              • 409
              Nick
              I had standard reds so when I went to the GT3 monoblocks On the front I needed custom brackets, not sure if the big reds uses the same brackets as the GT3 monoblocks .
              Same problem on the rear, I went from standard RS2 rears to boxter s monoblocks with custom brackets, I think they are the same discs as the standard rears...
              Sorry, it's not a simple answer but hope it helps a bit !
              Paul
