Originally posted by NoNonsense
Using a stock system, when you push on the brakes, a certain amount of fluid will be sent to the front and rear calipers, the ratio being determined by the bias valve.
If you change your front calipers for ones with much smaller internal cavities, in effect thsi will make the calipers bite much too early and way before the rears even come into play.
I'm sure those calipers would give all the braking force required, but I'd just be wary of the whole brake bias issue.
As I say - could be wrong - or blowing this whole issue out of proportion.
I do know of people with corrados (which use single pot calipers) - changing over to 4 pot Brembos without any issue.
Can anyone throw any experience or physics on the subject ??
. I'm not familiar with porsche models and this 996 doesn't mean something to me
