electrolysis brake caliper
  • hunker7
    • Mar 2014
    • 3487
    Just a quick question, I've taken the HP2's off to refurbish, can I use electrolysis to get rid of the rust? Never used electrolysis before, so don't on what it can be used and what not
    Thanks
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
  • irishs2
    • Apr 2009
    • 2455
    Yep, keep some brake line connected to the caliper so you can submerge without water getting it.
    I used water and baking soda.
    Eric
    95 S2 Avant under rebuild.
    • hunker7
      • Mar 2014
      • 3487
      I used water and backing soda.
      Awesome, you just saved me hours of scrubbing Is there anything that should be removed before? And for how long should I leave it in there for?
      Thanks
      '93 Audi UrS4 Avant
      • irishs2
        • Apr 2009
        • 2455
        I left it in overnight. Just quickly wire brush off the loose stuff. and clean one point where you can clamp the negative wire .
        Eric
        • hunker7
          • Mar 2014
          • 3487
          Brilliant thanks. I assume I can chuck brake discs in as well?
          '93 Audi UrS4 Avant
          • irishs2
            • Apr 2009
            • 2455
            I dont see why not if they are true and balanced.
            Eric
            • hunker7
              • Mar 2014
              • 3487
              Superb. Thanks alot.
              '93 Audi UrS4 Avant
