Brake disc ventilation?
  • Thuppu
    • 4115
    Is there any diffrence performance vise if the brake disc is vented to the outside or the inside of the hub?
    VS.
  • FabS6
    • Jul 2011
    • 205
    • Home: Italy Current: Spain
    No clue about the main difference but with the inner ventilation intake you could run an air pipe from the front to keep cool the discs. if no cooling pipes are there then I think it's the same thing...or not??
    Cheers!
    • s2driveruk
      • 12696
      just changed mine to pagid S8 discs and they are vented as the top image you have, so far no difference to report...
      1992 3b S2 Coupe
      • Laaf
        • Oct 2010
        • 275
        On the S4 I had the discs were different looking at OEM which were worn out and the Zimmermann I replaced them with. Think the OEM vented to the inside of the hub and the Zimmermann to the outside. Or vice versa, anyway, no difference to be felt.
        • Thuppu
          • 4115
          Lars, yes it's the OEM dics that are vented to inside, I also had B5 S4 OEM discs before, but now I did order MTEC grooved ones and they are vented to the outside. I was thinking of making airducts to the front brakes, like FabS6 was telling, but I have to forget them now. So I just thinking of is there any benefit of the vents to the outside..?
