Has anyone on here fitted and have an opinion on there rear calipers ?
Mine are beyond service and need to be replaced !
Two other things on my mind about them is, are the pads used same as original ?
Method of ordering parts from them is a little different than other sites,hows that work ?
Steve
1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
No pads are not the same and yes I think they are fine and lighter than the original calipers ofcourse. You need to be quick though as Paul is about to quit with his business
