I'm thinking of going either 280mm NB/Golf front disc or a turned down R32 front disc (it's like 320-ish and that is too big) rears to match a future set of 314mm A8 discs with 996-calipers. So, with that choice of disks - what calipers do I go for? I mean, I need a parkingbrake so stock URS4 might work (with a relocation adapter!). But - I want to go bigger with a p-brake.. Anyone here use BMW 840CS rear calipers? Apperently they are non-float 2 piston with p-brake built in - I haven't been able to find a pic or in anyway verify this statement but maybe you guys know.
How about 928 rear calipers? They are floting so they should have p-brake - but then again, Porsche just love commonality so I guess they didn't change the p-brake when they started to build the 928.
EDIT: Well after some concideration and searchin the forum I've come to the conclusion that I'm almost sure I need/want 323mm disks fron. Also, I'm looking at 312mm disk at the rear.
