I know a few people have fitted adjustable proportioning valves in place of the OEM fixed valve and I just wondered if there was much improvment to be had after fitting larger front and/or rear brakes? They are not expensive or hard to fit so I'm just interested in anyones experience of any improvments to be had on a mixed use weekend toy road/track car rather than pure track machine?
To remove the OEM valve in an otherwise stock set-up is pretty easy, the front line pressure supply to the valve can be plugged with a bleed nipple, and the OEM valve removed, with the adjustable valve plumbed in its place - pretty straight forward. Before anyone says, yes I am aware the stock valve is supposed to have a safety feature whereby it "monitors" the front circuit line pressure and in the event of a failure bypasses the proportioning valve and gives the rear axle full line pressure. I know of a couple of people who have had a front circuit failure and this was not their experience! They lost all brake hydraulics and had to use the handbrake to stop! So I'm not really concerned about loosing this "feature".
