345mm S8 & 996 Monoblocks
    Seen a few maybe threads but anyone actually done this with 425/426 Monoblocks?
  • martinjs
    • 3205
    You can get 6 pot cayenne calipers for not much more than those calipers.
      But I already have them
      • driftin jo
        • Sep 2007
        • 2222
        345 mm is too big for the 996 calipers, IIRC max dia
        That will work Is ~ 335mm.
        • s2driveruk
          • 12696
          345 didnt fit the 996 unless you started machining them...
          1992 3b S2 Coupe
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            Boxter S calipers are small... Unless you have only stage 1
            RED Mitsubishi Lancer Evolution VI TME nÂş 16 of 250
            BLACK Mitsubishi Lancer Evolution VI TME nÂş 189 of 250
              Need to sketch the discs next to each other, to investigate pad overlap.
              • twoqu
                • Sep 2003
                • 3103
                He did come in handy once in a while!
                  Yes, saw that but didn't really see the point in knocking 5mm off the diameter...
                  • twoqu
                    • Sep 2003
                    • 3103
                    Well part of the pad overhang or caliper fouling issues are not understood!
                    Strangely the S8 used the older 993tt type caliper with some Audi modification to the mounting bosses with presumably no such problems. Of course these are the older two piece rather than the monobloc.
                    Its the same issue more or less when tyring to use the A8 360mm disc with the 996TT caliper. Porsche upped the disc from 330mm to 350mm and thats about it with any issues.
                    • Colesy
                      • Feb 2009
                      • 2980
                      I was looking at a 345mm option with 429 and 430 big reds. There are a set of Mercedes discs that bolt on fairly easily, it's just the custom brackets that are the problem. I read that VRS have done it and I tried to get set of the brackets but didn't get anywhere so sold the calipers. Bambridge or someone from VRS might have more info.
                        Pick up a 345x30 disc. Then you will not want to use it! They weigh a ton!
                        • driftin jo
                          • Sep 2007
                          • 2222
                          i'll bet they do, my 323's are 10.5kg each and that's 2.5kg more than my wheels
                          • andy10v
                            • 5996
                            Are you planning on making a new carrier or just spacing out from the existing one?
                            Sold ABY-stock
                            • andy10v
                              • 5996
                              Also if you are getting a new carrier made what is your rough timescale?
                              Sold ABY-stock
