Porsche brakes on ur quattro clarification
  • robbie100hp
    • Dec 2012
    • 91
    I know this have been covered time and time again but I want to be 100% sure before I shell out.
    Iv decided to go with the Porsche setup as this means I can spend the money I'm saving over the ap setup on other parts that need refurbishing
    So I will obviously need the Porsche caliper, am I correct in saying that this is off a
    Porsche 996 carrera c2/4 , 986 boxster s 3.2 rear brake caliper
    And can some one confirm that the part numbers are as follows,
    996 352 421 03 n/s
    996 352 422 03 o/s
    Then I will need the bracket off bambridge
    Now which disc to go for,
    Some say 288mm disc what car is this off and what's the part number and where's the best place to buy them from?
    How ever I have read that sport quattro discs can be used these are a little bigger around 290 some thin, they are tight but I don't want to run spacers, are the brackets the same to run this disc?
    Where can I get them and what's the part number?
    Or is the quattro sport disc a little too close, meaning the brakes can't breath?
    What pads do people run?
    Stupid question but are the pads I need for a porsche ?
    Cheers guys
  • adam g
    • Feb 2007
    • 445
    I Used apec discs, I'll dig out the size I used and confirm caliper part numbers when I get my laptop on later.
    • adam g
      • Feb 2007
      • 445
      Below is an extract from a guy called (username) Harvey on the quattro forum, I believe he is the person who designed the brackets that Bambridge does. I have used the kit he describes, its spot on. The only thing you will be missing is brake pipes as the standard ones wont work.
      A couple of months ago I indicated I was going to design a bracket for a Porsche brake upgrade for the front of the ur. This was motivated primarily by the following:
      • serious brake upgrade that would still suffice if I ever went for more power.
      • keep the standard 8 x15 Ronals
      • did not want to have to machine the brake disc prior to use (as in some kits)
      As a result I have the following prescription for a brake upgrade that can be used in conjunction with 986 (Brembo) Boxster 2.5/2.7 calipers part # 986 351 421/2:
      The disc I designed the brackets around is an aftermarket copy of an Audi pattern. Specifically I used an Apec vented disc, DSK 911 (mildly ironic part #), at approx £40 for a pair from the local motor factor.
      • curlylee
        • Jan 2008
        • 424
        brakes
        where can i get the mounting brackets from are they still available
        • bambridge
          • May 2009
          • 609
          I have 2 sets of these brackets left, just waiting for some more m12x1.5 caphead bolts to arrive.
          I also have 2 sets of the ur/996 brackets left (DJones design)
          After these have gone, im not making any more
          • lcsmith
            • Jul 2007
            • 477
            I was going to ask you to make me a set of brackets for the 996.351.425/6 calipers to be used on S2 hubs with 323mm discs, any chance?
            Audi A4 (B7) 2.0 Tdi (140PS)
            Audi 80 (Typ 89) Quattro 16v
            2 x Audi URS4 2.2 20v Turbo
            Audi 100 (C3) Quattro 2.2 10v Turbo
            Audi 100 (C3) 2.2 10v Turbo (Auto)
            Audi 200 (C3) 2.1 10v Turbo - Scrapped
            2 x Audi 80 (Typ 89) Quattro 1.8 8v - Scrapped
            • curlylee
              • Jan 2008
              • 424
              i will take the 2 sets for the ur fitment cheers lee
              • robo
                • Aug 2004
                • 2086
                Both of these sets will fit ur, the second one needs a lot of work but you will potentially end up with 304mm disc under 15inch standard wheel.
                sigpic_________
                Rob
                • curlylee
                  • Jan 2008
                  • 424
                  i will have the 2 sets that are not d,jones pmd you tuesday no reply cheers
                  • audiman
                    • 4827
                    If you don't want to make anymore brackets, would you willing to pass on the drawing for the bracket? I have a local machine shop that could do the job for me.
                    Thanks
                    Tom C - www.rcmr.co.uk
                    Audi UR Quattro
                    Audi 100 C3 2.0 5 cyl 115ps
                    Audi B5 RS4 645ps 911nm
                    • Albert
                      • 1500
                      • Country: Poland
                      I will have a set for sale with brakes ready next month. It will be 300 mm disc setup with 986 boxster calipers. Will post photos when it is ready.
                      AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
                      • robo
                        • Aug 2004
                        • 2086
                        Thanks
                        What brake set up are you looking for Tom?
                        The biggest you can squeeze inside standard 15'' is 304mm and 996 calliper.
                        sigpic_________
                        Rob
                        • butchone
                          • Aug 2009
                          • 147
                          I did ask about this and pm'd you a number of times with no reply?
                          • Albert
                            • 1500
                            • Country: Poland
                            • butchone
                              • Aug 2009
                              • 147
                              Hello do you reply to any pm's? Or have you received the ones I have sent you?
