As a final kick in the nutts my Audi has blown the o ring under that big cross head screw on the steering/brake pump. If I recall they are a special O ring. Has anyone got the part number please?
Hydraulic pump screw seal
026 145 541 gets you a seal and screw. They were quite cheap last time I bought one, knowing Audi they'll be about a millions pounds now
I always put some Loctite on the screw too, helps seal it up
1976 RD250E / 350LC cafe racer -
It is special in the sense that the hydraulic fluid does not dissolve it like it does to lesser O-rings. Accept no substitutes.
DIY here: http://forums.quattroworld.com/s4s6/msgs/274239.phtml
To remove (and then tighten the new one, or try tightening the old one first) you need a drag link socket, like the one shown here:
With the corners chamfered off, like this:
