RS2 ABS light on Permanently relay fuse location ?
  • ian4455
    • Nov 2010
    • 787
    Can someone tell me the location of the fused relay for the abs on an rs2 please ?
    Fuse 31
    • ian4455
      • Nov 2010
      • 787
      Thankyou. Any advice as to why the abs light is on as soon as ignition is turned on and never goes out ?
      • s2driveruk
        • 12696
        must be different to the coupe as its under the dash, and slots into the top of the relay itself
        1992 3b S2 Coupe
          He did say RS2, hence I posted RS2 fuse box info.
          • s2driveruk
            • 12696
            yup didnt say it was incorrect, more of an exclamation that it must be different to the coupe
            1992 3b S2 Coupe
            • rj scotty
              • May 2006
              • 2195
              Will be due to locatin of the abs controller I would have thought.
              In the boot above/In front of battery on avant not sure where it lives on coupe
              BUT I DON'T WANT A NEW CAR!
              1995 S2 Avant, Volcano Black
              • s2driveruk
                • 12696
                battery problems or jump starting can cause them to pop a fuse too or it will be a sensor issue at a wheel
                1992 3b S2 Coupe
