Hi guys,i got this and i know they have been fitted to S4 b5 but is anybody able to confirm what are they?i think they are big reds but not sure.what it will need to fit them to S2 under 16"Avus (if possible)image.jpg
Brakes- what are they?
They look like Porsche 928 GTS brakes, are there any part numbers to go by? -
993TT Big Red
993-351-425-10 (left side)
993-351-426-10 (Right side)
928 GTS Big black
928-351-423-03 (left side)
928-351-424-03(right side)
both calipers is identical except,the bleeder nipple and X-tube are reversed.one of a few I5 from Asia.Comment
Brembo part# 20.5248/20.5249.00 would be a Big Red from 993TT(911) Calipers.one of a few I5 from Asia.Comment
993TT as others have identified. Same as the Mo'vit brake upgrade for S2's. Required to fit: bracket, spacers. Get braided hoses at same time if not already done. Check hat/bell dimensions. Plenty of pads available: see this thread (amongst others).Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...Comment
Mine are 15mm MTM hubcentric spacers (am sure you can get other makes and sizes):Attached FilesShocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...Comment
