330mm rear brake carrier?
  • Julian Iversen
    • Jul 2013
    • 84
    • Country: Denmark
    Hello, does someone know what rear brake carrier i need for 330mm rear brakes. As far as i know now it is from S6 v10. But I don't know what part number is has to be. 4F0615425(6)E or 4F0615425(6)F
    B7 RS4 should also work. Depends what calipers you are planning to use and what car its going onto.
    • Julian Iversen
      • Jul 2013
      • 84
      • Country: Denmark
      It's for my S2 Avant. I got the S4 B7 calipers. 8E0615423(4)J Does they fit the RS4 carrier? and does it fit on the car? A guy in switzerland have 330mm rear on his limo but he doesn't answer
        I think your B7 S4 calipers fit right on the B7 RS4 carrier and use with B7 RS4 rotors
        • mcandmar
          • Apr 2004
          • 5118
          I'm not 100% on the part numbers because i never wrote down what i used, but here is the main tread for the B7 upgrade http://www.s2forum.com/forum/showthread.php?t=22558
          91CQ20v - Gone to a new home
          93UR-S4 - The Magic Carpet
          94S2Bus - The Emerald Express
          • Julian Iversen
            • Jul 2013
            • 84
            • Country: Denmark
            Is the difference in part numbers on s4 and rs4 calipers then just because s4 calipers are steel and rs4 are aloy?
