AS i`M BROKE, ID LIKE TO KNOW IF IS POSSIBLE, (AND IF IT IS, WOULD IMPROVE) TO USE A8 BRAKE ROTORS IN MY ABY ORIGINAL CALIPERS AS THEY ARE A BIT BIGGER THAN ORIGINAL ONES. PROBABLY I WILL NEED BRACKETS ...
HOW ABOUT THE ORIGINAL S4 B5 FRONT CALIPERS ??? BETTER THAN OURS ???
CAN USE ROTORS TOO ?
ANY ADVICE ??
S2 Limo sold !!!
M5 E34 with some mods in the garage
sorry, but much happeir now !
ANY ADVICE ??
The Audi A8 rotors ( Disks) are thicker than the S2 disks. The S2 had the same front calipers throughout it's production run, Girling G60.
There is no quick and easy fix I'm afraid. The S4 had 2 different calipers, early and late. IIRC there was the UFO disks and there was a 4 pot caliper with small pads, this may be better but I don't know. Cossy Killer had some, maybe he could comment.
hp2 caliper is said not to vork on our cars,i myself am working on making a bracket so i can put the 312 *25 disc on with the oe caliper,´se my tread "need disc part number",ill
start working at bit harder when i have my sommer wheels on,cause at the moment i only have 15" on,but iam having 16" passat alu wheels refurbed for next winter.
