So the brake fluid is coming past the hand brake leaver so, is there a rubber seal there somewhere, and if yes where do I get one?
URS4 rear caliper problem
Its not that seal you need, there is one on the end of the screw shaft that the piston runs on, that is what is leaking. The lip seal under the lever is just supposed to keep the water out and the grease in.Panthero Coupé quattro 20vt
Imola B6 S4 AvantComment
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDIComment
Yes, that looks like the one, you're also going to need some of these to get the circlip ( item 21 ) out
http://www.ebay.co.uk/itm/Long-Nose-...item48363468c5sigpic
1976 RD250E / 350LC cafe racerComment
'93 Audi UrS4 Avant
Error404 gave you the answer. You should follow it.http://www.ebay.co.uk/itm/Audi-A8-V8...item4193ceae52 this will do?
The AAN rear caliper part numbers are 447615424 and 447615423. These are also the 1989-94 Audi V8 rear caliper PNs. There is no cross to the 1995 A8 and newer.
So that ebay kit *might* be correct. Check the PNs of the application, not the words "V8 and A8"
