Urs6 rear calipers vs. S6 C6 disc
  • krzysztofkabaj
    • Jan 2015
    • 36
    • Country: Poland
    Hey,
    Anyone tried such combination ?.
    Sfera è la divisione Server & Hosting premium del gruppo Register.it, parte di team.blue , realtà europea leader nei prodotti digitali per il business. Orig
    It would be regrettable to buy discs only to find out they do not fit
  • Thuppu
    • 4115
    They will not fit without custom caliper adapters. Offset and diameter is totally different from stock discs.
    • krzysztofkabaj
      • Jan 2015
      • 36
      • Country: Poland
      I'm aware of that Thomas. The adapater isn't problem tha could not be solved . I wanted to know if someone uses this set. Currently I run 310x22 wit 4 pot VW Touareg calipers but e-brake with cable is not supported by them . So the plan is to replace 310x22 + 4pot with 330x22 + series caliper.
      • Thuppu
        • 4115
        Well, I run 330x22 discs with Touareg 4-pots. There is quite tight of space, so the stock caliper(for e-brake) will propably not fit.
        I use the higher offset discs(49,5mm).
        • krzysztofkabaj
          • Jan 2015
          • 36
          • Country: Poland
          I wolud say 4 pots need more space, moreover using 310x22 and Touareg 4 pots na ET35 rims 5mm distance was needed. A6 C6 higher offset disc (49.5) would do the job because adapter will be less complicated than with S6 C6 disc (42.2mm offset).
          I think i give a shot with 49.5 offset disc ...
          • krzysztofkabaj
            • Jan 2015
            • 36
            • Country: Poland
            So I've decided to go 330x22 with 49.2mm offset like on Thuppu's posted image. Initial fit bellow :
            Could not help it, I need some "thing" to compare size .
            This weekend probably i'll mill some adapters.
            • krzysztofkabaj
              • Jan 2015
              • 36
              • Country: Poland
              Finally made adapters.
              330x22 disc + 43mm Lucas single piston caliper.
              • quattrostyle
                • Oct 2006
                • 6229
                Nice work, but don't you think the pad surface is quite small for the disc? As in, the pad does not catch the entire disc if you know what I mean.
