996 upgrade on RS2
  • Christian_88
    • May 2015
    • 33
    • Country: Norway
    996 upgrade on RS2
    Hello =)
    I have been reading threads about the 996 upgrade on the RS2, and it seems i need new brackets to get a perfect fit over the brake discs. i have asked some of the people who used to make them, but no luck. So i would be very greatfull if anyone could point me in the right direction as to who makes these brackets =)
    Christian
    - 95 RS2
    - 86 Cq
  • BRY
    • 3755
    If you want to lend me your car, I will make them
    • s2driveruk
      • 12696
      lol
      1992 3b S2 Coupe
      • Christian_88
        • May 2015
        • 33
        • Country: Norway
        No problem Come on over and you can take it for a spin without brakes
        - 95 RS2
        - 86 Cq
        • Albert
          • 1500
          • Country: Poland
          I can make them.
          AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
          • Christian_88
            • May 2015
            • 33
            • Country: Norway
            Another question. What disc options do i have with the fitted 996 calipers on stock RS2 brackets? And what options do i have on Custom brackets?
            Christian
            - 95 RS2
            - 86 Cq
            • matsabusen
              • Sep 2012
              • 24
              A litle closer, if i remember correctly someone in norway sells CP-service stuff
              Audi 90 quattro AAN -85
              Audi Coupe quattro Biturbo -93
              • Christian_88
                • May 2015
                • 33
                • Country: Norway
                Originally posted by matsabusen
                http://webshop.cp-service.se/search....uery=okadapter
                yes, there was. But the person who made the brackets has stopped making them. I have the original ones on now, but what i need to know is what disc size will fit on stock
                996 calipers on stock Rs2 adapters
                - 95 RS2
                - 86 Cq
                • matsabusen
                  • Sep 2012
                  • 24
                  • Christian_88
                    • May 2015
                    • 33
                    • Country: Norway
                    Yes, i have checked this. But these discs will only fit S2 circle 5*112 not RS2 5*130.
                    How is standard 996 discs or standard big red discs og the 996 brake upgrade?
                    i was hoping on a solution where i dont need to modify the brackets
                    - 95 RS2
                    - 86 Cq
                    • Christian_88
                      • May 2015
                      • 33
                      • Country: Norway
                      anyone?
                      - 95 RS2
                      - 86 Cq
                      • RS2junkie
                        • Mar 2011
                        • 409
                        • Home: Ireland Current: Bahrain
                        Hi,
                        I have GT3 monoblock callipers with Porsche 965 drilled & vented discs on mine, you need custom brackets. I got my brackets from VRS on this forum but I understand they were fabricated by Bainbridge, also on the forum. There is an upgrade on the rear too..
                        Here are the part numbers
                        BRAKES Front
                        911 GT3 Monoblock Callipers 996.351.429.10
                        996.351.430.10
                        Porsche 911 Turbo S Discs (965) 965.351.045.00
                        965.351.046.00
                        Pads 996.351.940.12 ATE
                        Calliper Support Brackets Custom VRS
                        Rear
                        Boxter S Rear Monoblock Callipers 996 352 421
                        Porsche 928 S4 Drilled & Ventilated 951 352 041 01
                        Pads 999 073 40201
                        Handbrake Shoes 996 352 993 01/1
                        These fit under the standard RS2 wheels with no issues.
                        Hope this helps
                        Paul
                        • Ruhmic
                          • Feb 2010
                          • 44
                          Hello Christian88,
                          can you post the part number from your Brake caliper?
                          At the Porsche 996 you have some different discs and calipers.
                          One setup have 318x28mm disc. Another setups have 330x34mm discs and 350x34mm.
                          • Christian_88
                            • May 2015
                            • 33
                            • Country: Norway
                            Originally posted by Ruhmic
                            Hello Christian88,
                            Hello, and sorry for a very late answer. The part number on tha caliper is 996352425. After removing some metal from the 4 pins i got it over the disc, but it still is about 0,5cm before it is center with the caliper bracket.
                            Christian
                            - 95 RS2
                            - 86 Cq
                            • 90/90qs
                              • Jun 2006
                              • 244
                              Maybe I'm missing something, but you want to go from the 993tt type to 996?
                              Am I confused about stock RS2s?
                              Anyhow Apikol sells brackets that may suit. They still list brackets on the site, but I can't comment on your specific application
                              http://s260.photobucket.com/albums/ii11/minipitt1/
