URS4 rear calipers.
  • Dift
    • Nov 2014
    • 282
    URS4 rear calipers.
    Where is the best place to get rear calipers?
    One is on its way, and the other is following suit. Euro car parts have a rear right at £120, is there anywhere else?
    Or has anyone got some good condition second hand?
  • shaun5
    • 1610
    Let me guess the handbrake doesn't work properly? If it is, first thing to check is that the cables are free If they aren't seized then putting them in my de-rusting solution could solve your problem
    • Dift
      • Nov 2014
      • 282
      Thanks Shaun.
      I put new discs and pads on. It was very difficult to wind the piston back in... Now they just don't move. I dragged it to a garage whose replaced a load of bushes; and one caliper is pretty seized, the other not far off.
      As the car will carry my family from time to time, I'll just stump up for new ones...
      Thanks for the help everyone... I've been offered some for £85 each for Monday delivery!
      I've not had a bill yet
      • hunker7
        • Mar 2014
        • 3487
        £10 for seal kit and about an hour work and calipers would be like new (and money left over for more "go faster" bits)
        '93 Audi UrS4 Avant
        '15 Audi A7 quattro 3.0 TDI
        • Dift
          • Nov 2014
          • 282
          I just don't have time unfortunately.
          If I replace the rear calipers than everything is new on the rear axle pretty much.
          It's going to be an expensive disaster this roadtrip
            UrS Rear Caliper Replacement DIY info
            Originally posted by Dift
            I just don't have time unfortunately. If I replace the rear calipers than everything is new on the rear axle pretty much.
            UrS Rear Caliper Replacement DIY info:
              I got some new TRW ones (yes brand new not not reconditioned) recently, around £85 each. They are the original Girling units in a TRW box, so same as OEM. In fact you can see where they have ground the Audi part number off the casting.
              P/n BHT108 , BHT109
              HTH
              • Dift
                • Nov 2014
                • 282
                Thanks guy ... Looks like a busy weekend ahead.
