Got my C4 A6 back yesterday from having S6 struts and HP2 brakes fitted. Although the new brakes work fine the pedal is quite spongy despite having been bled through four times. The pedal was fine with the old strut/brake combo. I had rebuilt the calipers with new pistons and seals so they were empty of fluid when fitted and I'm wondering if there is some special way of bleeding them that gets all the air out. Either that or is there a difference in bore of the master cylinder between the A6 and urS6 that means the A6 master cylinder can't shift enough fluid for the HP2s?
Any thoughts or BTDTs would be a great help
David
David
