Not much different from johnb's conversion although there is a good write up for this there were however a few things i found that didn't go smoothly as i had hoped but hey i'm there now so a few pics.
The handbrake carrier doesn't quite sit flush with the hub as the guy in work drilled the holes to m10 didn't drill them straight so when he tapped them they are at a slight angle so when i put the bolts in along with the three 1mm washers in the top hole the bracket was touching the disc on the bottom so i only used 1 2mm washer and although still slightly at an angle it cleared the disc enough.
Then i mounted the caliper carrier.
[URL=http://s1180.photobucket.com/user/bilko0795/media/93D4B777-3F06-4D48-9840-657C9F848B5E_zpssmgxzmck.jpg.html]
[/URL
Next the Disc.
First i tried the 996 turbo rear caliper because it was (Red) but alas didn't sit right the pads were only toucning half of the disc
: I KNOW THE CALIPER IS UPSIDE DOWN BY THE WAY
Any way mounted the handbrake caliper looks good
Fitted the brake hose to the new brake line i had to have made
normal form the nut was knackered on the old one.
Then took off the red caliper and replaced with the 986 caliper had an issue with the the holes on the caliper not lineing up with the on the holes carrier didn't have this with the other caliper anyway placed a 2mm washer behind each fitting hole and bingo fits a treat.
Then it was time for the Handbrake cables what a palaver fitting these B------S Avant cables are still to long they could be 1ft -18inches shorter there is a place in nottingham where i had my handbrake calipers from that make custom handbrake cables i will give a shout. i will upload the pickys for cables shortly.
[/URLNext the Disc.
.Fitted the brake hose to the new brake line i had to have made
.Then took off the red caliper and replaced with the 986 caliper had an issue with the the holes on the caliper not lineing up with the on the holes carrier didn't have this with the other caliper anyway placed a 2mm washer behind each fitting hole and bingo fits a treat.
