OK, we will see, what result it will be at the end
Purchased set of 996 rear brake calipers ...
It seems that it is possible to fit 30mm diameter disc on those, if grind some meat from the pads. Now it is time to find someone who can properly calculate (don't want to kill myself) and make adapters for these things to fit typ85 struts. Also someone who can drill discs for 4 bolt pattern which I'm currently using on my coupe.
BTW is it possible to purchase american audi a8 rotors in Europe ? Maybe Zimmerman makes those ?
Long way to go, wish me luck
Sau
.Purchased set of 996 rear brake calipers ...
Sau
. So I'm used to it.
