Just a thought, have read about the test for the bomb, if you press the brake pedal like 20 times and above until the pedal gets hard with the engine off (bomb is ok) but if it´s like 5-10 times then the (bomb is broken) but if you don´t feel any pulsating with a broken bomb then? or isn´t that possible? Or if the bomb is okay but you still don´t have so good brake assist it can only be lack of hydraulic fluid / bad pump / clogged lines? Just need to test this properly I guess before I build it to vaccum style, maybe I have a problem that I have missed... thanks guys for the help
Hydraulic to vaccum brake conversion Urs6
If it gets hard after 5-10 times it means that the bomb is not new and has seen quite a life. But until it's not vibrating, you're fine. I'm very happy with my single-membrane vacuum from C4. If you want to get a dual membrane then go for it, but it's really not worth the hassle, you wont feel any big improvements.
Remember to bleed the brakes, starting from the farthest wheel from the brake cylinder.
the lesser counts on pressing the pedal means the bomb is getting tired and couldn't much reserved assists.as long as no pedal pulsating,there should be no problems Goeran.i had my old bomb which can depress only 2 times with the engine off but it was still doing its job nicely though.one of a few I5 from Asia.
Hmm so if the bomb is new or tired it doesent affect The brake assist? Have bleeded the new brakes several Times and they work great and no warning signs (!) but the pedal still feels hard and after som heavy braking it feels like lack of brakeforce and you have to press harder hmm... Maybe something is wrong in The lines or pump... Cant drive for The moment thue to turbochange and get my missing bolts on monday perhaps1995 Audi S6 - AAN (~350hp)
2008 BMW 530xd (235hp)
