I have intermittent brake feel issues, yesterday pulsing pedal, today not enough stopping power, this happened about 6 months ago and then disappeared.
I have no Red lights, no beeps, brake bomb test seems to reveal little as the peddle is always hard even when the braking feels good (well as good as I have known, only owned for 9 months), ABS works when needed
Fluid looks good (green, full, no apparent leaks)
I am about to fit 996 + A8 front upgrade (just waiting for hoses) so timing is perfect.
Is there any sure fire way to determine Bomb is at fault or is it worth checking elsewhere first.
Do I Fix the problem before upgrade to eliminate the fault or upgrade ASAP and check braking ability after?
Either way, time is of the essence as I don't know if I could stop quickly enough if required at the moment.
