RS2 Big Red (from Little Red) Conversion!
  • UUUdirs2newcastle
    • Apr 2008
    • 655
    Would I be right in saying that I can fit the 'Genuine' Big Red caliber carrier from Audi, and then I can got the bigger discs?
    Is it only the caliber bracket that makes 'Big Reds' over 'Litte Reds' ?
    I am guessing that the brake caliber itself is the same part number?
    *Can anyone reliably confirm the Porsche 'Front Disc' part number for 'drilled' 304mm discs that will got a set of 'Little Reds' ? I am thinking that it's the same part number as the Porsche 968 CLUB sport (Drilled Front Discs)?
    Many thanks guys. 👌
  • veneto rs2
    • Jun 2006
    • 1022
    • Country: Veneto
    You don't need to change the caliper carrier/bracket to swap from little reds to big reds.
    Original RS2 caliper carrier can hold both big or little reds.
    You need the bigger calipers to fit the 322mm bigger discs
    http://www.audisportclub.com/
    • LGK6D
      • Oct 2011
      • 288
      The big red front calliper is from a 993 Turbo and needs the 322mm disc. They callipers are available from Porsche but not from Audi. Make sure you're sitting down when you ask for a quote. The calliper carrier isn't different. The rear calliper stays the same, but the disc are drilled to match the fronts.
