Porsche as bleeding the brake?
  • [sTeeWie]
    • Jul 2011
    • 106
    As you vacuuming your Porsche calipers?
    I feel that I have the air not completely get out of my front Cayenne calipers.
    I deflate with a eezibleed. So with pressure.
    I also found that after a prolonged highway driving at a high speed has a poor braking action. Whether related to it?
    Did you flip the Cayenne calipers Left to Right and Right to Left so the bleeders point up?
    Not like this:
    • dhali7376
      • Nov 2009
      • 301
      Common mistake that
      • Rikki Kitto
        • Feb 2010
        • 6276
        Or this
        • [sTeeWie]
          • Jul 2011
          • 106
          No, my calipers are fitted, as it should. Small piston down and bleed screws up
            Originally posted by Rikki Kitto
            Or this
            Yeh. That.
            • dhali7376
              • Nov 2009
              • 301
              Did you bleed whole system? Also on the Porsche calipers you have to bleed the inside first. Some people also lightly tap the caliper as they are bleeding them . Wether this helps I don't know.
              I would bleed the whole system again.
              • rj scotty
                • May 2006
                • 2195
                I believe Alex looked into this and ended up bleeding the calipers with them detached from their mountings.
                This enabled him to manipulate them and free some trapped air bubbles
                BUT I DON'T WANT A NEW CAR!
                1995 S2 Avant, Volcano Black
                • [sTeeWie]
                  • Jul 2011
                  • 106
                  Then I'll again bleed the entire system.
                  So you should, if necessary, tap lightly from behind times with a rubber mallet against the caliper?
                  • PRY4SNO
                    • 767
                    Don't forget the master cylinder when you're bleeding.
                    Bleeding my BoxsterS calipers was a royal pain in the derrière, took four times to get all the air out of the system.
                    2013 Touareg TDI /// #farmenwagen
                    • pasbogdan
                      • Sep 2009
                      • 1160
                      • Country: Romania
                      The design of the caliper should get any air in the upper part at the bleed exit.
                      • [sTeeWie]
                        • Jul 2011
                        • 106
                        Should I vent to the pedal, so I can get the air even from the master Cylinder?
                        • Dima ABY
                          • Sep 2013
                          • 183
                          • Home: Ukraine Current: Spain
                          No.With your eezibleed procedure,master cylinder is bleeding by himself too.
                          No issues with old brake setup?
                            If you have poor brakes after cruising then the pistons are being pushed back into the caliper by the disc - disc has run-out or caliper and disc are not aligned properly. Probably dirty hub face or bad caliper bracket.
                            You should also bleed at least 500ml fluid out of each caliper and pump the pedal plenty to release small air bubbles.
                            • Tony Stark
                              • Nov 2009
                              • 288
                              As error said, plus freeplay in wheel bearings, brake pads not moving freely in the caliper also if the pads and discs aren't yet bedded in you can have a pedal that doesn't feel as good as it should.
                              Any work been carried out on the rears?
