Can anyone help me out by telling me how the ABS unit knows the diff lock is engaged? I.e what pins on the abs ECU receive a pos or neg?
I have an abs fault which I am struggling with and I want to rule out the diff lock situation.
The relays and pump do not run on self test when turning the ignition on but all the feeds seem to be present at the Relays and ABS ECU. I get the feeling it is being deliberately disabled somehow.
MY 1995 S2 Avant without the dash mounted ABS disable switch.
Thanks!
Glen
Thanks!
Glen
where is "relay" 76? I assume that it is a double wide or double tall control module with an external fuse?
