Rs4/6 8 pots but what's discs
  • mac2226
    • Jun 2008
    • 1289
    I've been offered some 8 pots from a rs4/6 vw phaeton but my question is what's best discs to use phaeton 360mmx34mm/365mmx34mm or can I use the rs4 floating two piece discs or is this not possible and also gsf do Zimmerman 365mmx34mm discs,could someone make custom brackets for s2 coupe either of above discs options
  • Sonic
    • Jul 2006
    • 5514
    I use 365x34mm phaeton discs, but either way you want the phaeton bells. You can run the rs4 rotor with the phaeton bell, and yes it requires a custom carrier. IIRC AndyP / Bry did some of these - i ended up with a custom aluminium billet job from a member called Neo in Sweden but i don't think he makes them anymore.
    S2Forum.com Administrator
    • mac2226
      • Jun 2008
      • 1289
      http://www.s2forum.com/forum/showthread.php?t=15713
      Thanks sonic I've ordered phaeton discs but on vw computer it's not a very good picture showing if it's a two piece disc as I need the bells and m8 bolts nuts as well but no part number? Unless discs come with bells attached? I soon find out tomorrow morning
      • Sonic
        • Jul 2006
        • 5514
        My discs always came with Bells. I have a full set in the garage with one disc very slightly warped if not.
        • dubmanted
          • Jun 2014
          • 312
          I believe my setup uses rs4 365mm discs with phaeton bells too
          • mac2226
            • Jun 2008
            • 1289
            That's what I thought sonic as there's no part number for bells on there own,only what I provided them with part number 3D0615301N
            • mac2226
              • Jun 2008
              • 1289
              I think 365mmx34mm phaeton discs are same as rs4/6 discs but are plain discs not drilled, I have pair of used rs4 b7 two piece discs and bells 365mmx34mm but worn to 31mm so not usable and was going to order just discs from Audi and make custom brackets to fit on my s2 coupe
              • LucheS2@20v
                Banned
                • Nov 2015
                • 115
                • Country: Bulgaria
                Will you change the pump?
                • mac2226
                  • Jun 2008
                  • 1289
                  Sorry what do you mean?
                  • Sonic
                    • Jul 2006
                    • 5514
                    Presumably the master cylinder? No need.
                    • mac2226
                      • Jun 2008
                      • 1289
                      I'm fitting a vac servo instead of hydraulic one and ditching bomb won't know till its all bled up and tested but I presume it should be fine
