Morning all
I've done some work on the brake system, including changing the master cylinder and reservoir, which has resulted in fault code 00259, N99 Inlet valve error
I expect trapped air and the pump needs to cycle properly to expel it, I have bled the brakes using the standard proceedure but I am unable to bleed the ABS unit, I don't have the proper tester and Vag-com won't do it, as it's too old.
Anyone done this by triggering the pump?
From the attached CFD, I am looking at bridging the pump connector 8 to +12v and 5+10 to ground
Can anyone confirm this is correct to run the pump?
Andy
Andy
