UrS4/6 rear brakes on S2?
  • Rusty
    • 18953
    Do the vented rears fit or are the hubs a different bolt spacing / offset? Both use 245x10mm setups but the poart nos are different. Not heard of them being used...
    URS4/6 used iirc 269 x 20 vented rears
    • Colesy
      • Feb 2009
      • 2981
      For coupe fitment I think the hat height of the 269mm discs is too much, hence the use of machined down S8 discs in the usual conversion.
      Paul gives a good write up here: http://www.s2central.net/main_frame.html
      • varia
        • 821
        • Current: United States
        in my cq the rear:
        Audi urS4/6 rear calipers
        Audi B5 S4 rear caliper brackets
        Audi B5 S4 rear vented brake disk
        however i had original s2 hub, and had to use b5a4q rear hub, cos that extra 8mm offset
        • HMS-S6
          • Jan 2010
          • 1164
          I recently did the conversion from that page on an S2 avant for a customer, works very well
