I've decided to try the cheaper option for brakes! Zimmerman drilled disc's on the front with Pagid fast road pads and fast road pads on the rear too! (can't get the rear disc's anymore! discontinued! ) I came to fit it all tonight after work and found the front pads are miles too small!! tiney in comparrison to the OE! Anyway its just got the drilled discs on the front at the mo, i got hungery so i came home for me T! Even though there not bedded in to the pads yet (initail bit is a bit crap yet), there is a noticeable difference in slowing at speed! (also a bit noiser too) Should be much better when all fitted and bedded in! (although iam not expecting too much as it is the cheap option after all, all in at a smidge over a one'er!, pretty cheap in anyones book!) Suit you sir! suit you!
I'll keep you all posted on the poor mans upgrade!
Glen C.
Glen C.
