Castrol srf compatibility?
  • gavs20v
    • Sep 2004
    • 3057
    ey oop, ive got to bleed the brakes on my s2 this weekend, does anyone know what other brake fluid is compatible with castrol srf? dot 4 maybe? I need to do this, this weekend and cant source any srf thatll get here in time
    Cheers in advance
    Gav
    S2 Cabriolet.........
  • dan_b
    • Sep 2003
    • 3670
    SRF is (I'm pretty certain on this) a silicone-based fluid, which therefore doesn't mix well/ at all with normal DOT 4: you have to fully flush the whole system with SRF first to use SRF?
    • gavs20v
      • Sep 2004
      • 3057
      Yup it was fully flushed.
      What a ballache!
      Cheers anyhoo!
      Gav
      • dan_b
        • Sep 2003
        • 3670
        Hey Gav, where abouts in Canterbury do you live - grew up in that area, quite often come back to Kent to see the folks etc.
        • gavs20v
          • Sep 2004
          • 3057
          im just outside in Aylesham near wingham. Used to have a lousy reputation due to it being a mining village but touch wood never had any problems, and its close to Lydeen hill and canterbury which is a bonus.
          Nice one
          Gav
          • The Spanish
            • Nov 2003
            • 719
            Castrol SRF is not silicon based so it doesn't happen anything if it mixed with other fluids. For better performance it shouldn't but it will not harm the system.
            It is DOT 3 based and I use it in my car (a friends gives it to me for free) very expensive though.
            I have a can at home, I might re read the label but I am sure it won't happen anything if mixed with Audi fluid, just make the fluid worst though.
            94' RS2 Coupe TT (Twin Torsen )
            • gavs20v
              • Sep 2004
              • 3057
              Hi Spanish thatd be great if you could have a look at the label and let me know, for peace of mind if nothing else.
              Gav
              • dan_b
                • Sep 2003
                • 3670
                Sorry, but SRF is silicone based -
                Gav - bloody hell: I grew up in Staple, which is just 2 miles from Wingham and about 4 miles from Aylesham!
                • The Spanish
                  • Nov 2003
                  • 719
                  Info here. http://www.racerpartswholesale.com/srf1.htm
                  It does say it has some silicone but is not a silcon fluid DOT 5.1 which do not work with ABS equipped cars.
                  The part you wanted is this:
                  Castrol SRF exceeds the US Federal Standards FMVSS 116 DOT 3 and DOT 4, ISO 4925, JIS K2233 and current SAE J1703 and is miscible with all conventional brake fluids conforming to these standards. However, mixing Castrol SRF and conventional brake fluids will reduce the benefits of Castrol SRF. It is strongly recommended that conventional brake fluid be drained from the system before flushing and re-filling with Castrol SRF
                  • dan_b
                    • Sep 2003
                    • 3670
                    Impressive dry boiling point isn't it: 310C? Wet BP is very impressive too 270C. Good fluid.
                    • The Spanish
                      • Nov 2003
                      • 719
                      LOL we posted the same link.
                      You are right about silicone but my point is it is not DOT 5.1 that cannot be mixed with anything and this can. At the can it says something about being DOT 3 believe me.
                      So both of us were right (almost )
                        Castrol SRF is *the* best brake fluid out there. Its wet boiling point is amazing. Only grief with SRF is the price and that you MUST bleed it at least once a year as it absorbs moisture faster than traditional fluids.
                        Paul
                        • GandalfS6
                          • 332
                          • Country: South Africa
                          Castrol SRF is a DOT 3 fluid - great stuff but very expensive. Try Motul RBF 600 - works nearly as well but for a 1/3 of the price.
                          1995 Silver S2 (ADU) Coupe
                          2006 Porsche 997 Carrera S
                          2006 Misano Red RS4
                          2004 VW Touareg V8
                          2007 Golf Mk1 Race Car
                          2004 Mercedes Benz Vito 112CD
                          • s2-1.5bar
                            • Sep 2004
                            • 193
                            • Home: Lithuania Current: United Kingdom
                            Agree, so u can change it 1 once a year without paying a fortune
                            • gavs20v
                              • Sep 2004
                              • 3057
                              OK so Dot 3 is compatible but not dot 4? is this right? Anybody know who stocks the motul RBF 600?
                              Cheers Guys
                              @Dan , yup i know Staple we go past there when we go for a rideout on the bikes, small world eh mate, definite lack of s2's in the area though.
                              Nice one
                              Gav
