Which manufacturer's balance discs?
  • gnutz2
    • Aug 2006
    • 928
    Does anybody know which manufacturer's actually bother to balance their discs before I go ahead and buy a new set? If its oem spec then it should be balanced but I know some don't bother!
    I've been running mintex for years and have come to the conclusion that they are the cause of my vibration because they didn't bother to balance! Im running the 323x30mm a8 discs and vibrations start at about 145mph and get pretty bad at 165 so I've not bothered going above that speed.
    Tyres have been balanced and it happened with my last set of tyres so im confident they're not the problem.
    Cheers Baz
    The ONLY S2 Golf!
    10.42@138mph
  • s2driveruk
    • 12696
    Pagid seem to balance theirs, you can see them on the outer edges where they have been balanced, my existing A8's have them
    1992 3b S2 Coupe
    • A1QSHIP
      • Aug 2004
      • 975
      I use a Pagid brand, 323X30 A8 rotor as well. The rotors are definitely balanced & show the balance marks on the outer edge. They are also coated & do not rust up as easily as other rotors I have seen.
      "Nulla tenaci invia est via"
        Sure Brembo do, there are areas machined out of the outer circumference
        • gnutz2
          • Aug 2006
          • 928
          Thanks for the replies
          Spotted some coated pagid discs on eBay for reasonable money.
          The ONLY S2 Golf!
          10.42@138mph
          • SE_30
            • Apr 2010
            • 1114
            • Home: England Current: Israel
            Another for the Pagid A8 discs, as per Alex's post above.
            Stuart
            B2 90 quattro with boost
            • Audicted
              • May 2004
              • 366
              • Home: Jamaica Current: United States
              Originally posted by gnutz2
              ..... vibrations start at about 145mph and get pretty bad at 165 so I've not bothered going above that speed.....
              Cheers Baz
              What roads are you driving on at those speeds?
              • mike74
                • Apr 2014
                • 615
                maybe its not the discs?
                • gnutz2
                  • Aug 2006
                  • 928
                  Some brembos are on their way.
                  Hopefully I'll test them out on the standing kilometre top speed run at TOTB!
                  The ONLY S2 Golf!
                  10.42@138mph
                  • SE_30
                    • Apr 2010
                    • 1114
                    What date is that on?
                    Stuart
                    • gnutz2
                      • Aug 2006
                      • 928
                      Its on the 30-31st of july, not long!
                      Its £100 entry and that gains access to Saturday testing as well as racing on sunday. It's three disciplines, top speed, quarter mile and handling.
                      If the weather holds off it'll be a cracking weekend.
                      The ONLY S2 Golf!
                      10.42@138mph
                      • SE_30
                        • Apr 2010
                        • 1114
                        Might have a look at that Baz, thats as long as the wifey doesn't scupper those dates with a holiday.
                        Stuart
                        • V6quattro
                          • Sep 2008
                          • 949
                          Nice! I still have to do that once with my car. Maybe next year
                          1360kg/600Whp Avant 0-200km/h 9sec
                          • gnutz2
                            • Aug 2006
                            • 928
                            Can't promise I'll be there either looking at the current state of the car!
                            The ONLY S2 Golf!
                            10.42@138mph
