If one was contemplating upgrading the front brakes on a UrS6 from oem to either Brembo 17z or 18z calipers and one wants to avoid any longer brake pedal travel than oem, does one need to change the brake master cylinder to a bigger brake master cylinder ?
If one does which car has the bigger brake master cylinder ?
The above assumes that the pedal travel cannot be adjusted to be longer or shorter ?
Thanks for any assistance.
only thing I would consider is vac brake servo to get a more modern feel to the brakes, but it works good as it sits...
