Using 16" rims which rear brake upgrade fits
  • orsum
    • May 2010
    • 1213
    • Home: United Kingdom Current: South Africa
    The important thing for me is the 5 spoke vs the 6 spoke apparently there is a difference.
    From my reading (only reading) I interpreted the 323 disc fits under the 6 spoke Avus ABY rim when using the RS2 Carrier and 996. 425/426 Caliper. If it does not then yes I will make suitable mods.
    The next important thing is the rear brake to match the front setup.
    Thanks UrS4boy for correcting the naming of the rims.
    orsum
    • Henkjan
      • 1705
      it's not the # of spokes, but the rim design. The Speedline will not fit over the brakes without spacers for the weels (and might fit with, ymmv), Avus most likely will fit.
      • orsum
        • May 2010
        • 1213
        Thanks for all the support on the fronts.
        Any more comments on the rear upgrades fitting under the Avus 6 spoke rims.
        orsum
        • andy10v
          • 5996
          I dont know about the other rear brake calipers, this was my car with the parts list I posted earlier
          Sold ABY-stock
          • orsum
            • May 2010
            • 1213
            #20
            Thanks andy10v,
            What did you have on the front?
            orsum
            • andy10v
              • 5996
              996 calipers, A8 314 discs, Bambridge 996/314 brackets, hardlines (I would use flexis if I did it again for easier future service)
              Sold ABY-stock
              • gavs20v
                • Sep 2004
                • 3057
                Slightly off topic however does anyone know off hand what the biggest disc size is possible under a 17" wheel?
                Thanks
                Gav
                S2 Cabriolet.........
