If any of you guys have got something like a diagram for all brake pipes location starting from ABS module?I made my little diagram when I stripped it all down and I can't find it now and I don't want to mix it all up .
Brake pipes location
You have 2 input & 3 output, the ports are labelled on the ABS unit.
Can't remember off the top of my head which way round the labelling is; either the inputs are in capitals i.e. H, V or the output is in capitals. Have a look.
input - front (V)
input - rear (H)
output - front right (VR)
output - front left (VL)
output - rear (H)
You also have the rear circuit brake pressure regulator. You should be able to find a pic showing that arrangement of that.
HTH
AlexPanthero Coupé quattro 20vt
