993 C2 + A8 Discs
  • Dave cook
    • 312
    993 C2 + A8 Discs
    any ideas if 993 C2 ''big black'' calipers fit
    a 323mm a8 disc with RS2 brackets?
    can anyone help me
  • BRY
    • 3755
    Part no's for the calipers would help.
    • twoqu
      • Sep 2003
      • 3103
      Hi!,
      This is where it starts to get confusing!
      In essence, the 993tt AKA "Big Reds" do. The 928 GTS used the "Big Blacks", which should also be OK. Seems there are different pistons set ups between Reds/Blacks. I have seen Carreras with the turbo brake option but the calipers are black. If you have those, they should be OK. You will need to swop the bridge pipes/nipples over if you alter the orientation of the caliper from leading to trailing.
      • Mikes2
        • 1704
        The 993 C2 doesn't use Big blacks - they are small blacks. This is what I have. I use the 314mm disc machined down to 304mm.
        Mike
        http://www.s2-audi.co.uk
