D2 A8 brake calipers any good?
  • dubmanted
    • Jun 2014
    • 312
    Hi guys im sure i read somewhere that D2 A8 rear caliper carriers are an upgrade for URQ's and S2 coupe's?
    Is this the case?
  • LHD_Kid
    • May 2006
    • 3695
    Is this the case?
    I think there are 2 types - there is a Brembo version which is definately an upgrade. But it isn't a simple bolt on. You will need caliper carriers
    • dubmanted
      • Jun 2014
      • 312
      Thanks for the reply. Any idea if they came from a V8/V6/S8?i
      Thank you
      • LHD_Kid
        • May 2006
        • 3695
        Thank you
        Pretty sure they're S8...
        Edit. German ebay - Linky
        • HPsauce
          • Sep 2015
          • 227
          Isn't that eBay link for fronts?
          • LHD_Kid
            • May 2006
            • 3695
            Yes I didn't read properly. Hence the pic also of a front...
            Then yes.... D2 S8 rears with caliper carriers will bolt straight on... although I'm not 100% sure on the disc... and not Brembos.
            Sorry for being a div...
            • HPsauce
              • Sep 2015
              • 227
              Just happen to spot this on the A8 forum re D2 S8 (facelist) rear brakes:
              Rears were 280mm x 22mm with calipers by Lucas. Brembo dont now do the rear discs (used to be 09.7196.10) but they do provide pads - P85 020
              • piotr
                • Jul 2012
                • 1470
                Them discs do not fit to S2 Coupe with above callipers and carriers .Would be nice to know if there is any plug and play disc
