Audi S2 3B
  • ristokru
    • Oct 2016
    • 270
    Audi S2 3B
    Hello,
    i have a S2 sedan replica. Audi 80 body and 3B technics on it.
    I have a question about brakes system. If i but pedal to the floor and then suddenly brake,then the brakes are off. They will brake but without power.
    If i drive normally then brakes are good.
    What may be the issue? Brake silinder?
    Thanks!
    Hydraulic or vacuum booster?
    If you have vacuum it sounds like the check valve is not working.
    • ristokru
      • Oct 2016
      • 270
      http://kuldnebors.ee/search/soidukid...b_page_size=25
      I dont know can you see it from engine picture?
        Can't quite see, looks like vacuum booster to me.
        • ristokru
          • Oct 2016
          • 270
          Yes,its vacuum booster.
            So make sure that the check valve is OK, otherwise the booster will not hold vacuum and you have no assist until engine builds vacuum. It is a good idea to use 2 check valves in series on a turbo motor, so you don't boost the servo & damage it.
            • RichLV
              • Mar 2015
              • 872
              • Country: Latvia
              How do you fit 2 valves? I wanted to do this too, but haven't found valves which can be placed in series.
                Just cut the vacuum pipe to the booster and add another valve in series.
                I used 191 611 933 from the VW bus
                • RichLV
                  • Mar 2015
                  • 872
                  • Country: Latvia
                  What kind of booster do you have?
                  • ristokru
                    • Oct 2016
                    • 270
                    How can i check is the valve ok?
                    And is this stronger:
                    http://www.ebay.co.uk/itm/331470792631
                    • LHD_Kid
                      • May 2006
                      • 3696
                      It is a pain to fit the forge one as the pipe diameter is larger. Just fit 2 good OEM ones
                        OEM is perfectly good enough, probably better in fact.
                        • ristokru
                          • Oct 2016
                          • 270
                          How can i check is the valve broken or maybe booster?
                          • LHD_Kid
                            • May 2006
                            • 3696
                            Remove the valve - noting which way it was mounted.
                            Suck and blow through it, flow should only be possible in the direction away from the vacuum servo.
