Gapping the sensors is pretty basic - push them in all the way, until they touch the ring. Then pull them out 0.5-1.0mm.
Maybe its not the gap, in which case you need to get a scope on the sensors, measuring AC voltage.
You can then compare the readings from the 4 sensors, either by running the car on the ramp or on the road (road would be a better test).
