Floor mounted pedal box conversion
  • pinotattt
    • Jan 2013
    • 174
    • Country: Malta
    Hi all. My car is an audi s2 aby engine. I have a problem with my floor mounted pedal box conversion. I eliminated the factory master cylinder inclining the power brake system. I just closed off the supply from the power steering pump bur when I started the car, oil started spitting out from the x plug. Do I have to supply the feel I closed off somewhere or do I have a problem with my pump? I have a spare pump off and aan audi s4.
  • jade
    • Jan 2005
    • 1811
    You cannot exactly close it off pressure needs to go somewhere, you will need to remove the 2 pistons from the pump which are located under the 2 x plugs
    RS 2 580HP
    • pinotattt
      • Jan 2013
      • 174
      • Country: Malta
      Thanks for your reply. Would I be able to put a pipe from the pressure side into the resevoir? Or is there too much pressure? Re removing the pistons....could it be done? And guides?
