I've spent today getting all my calipers resprayed. I'm well pleased with the results. Only trouble is it shows up that the wheels need doing now too Here's some before & after pic's:
I did it together with a mate who is a mobile paint repairer . I did all the 'prepping' and he did the spraying.
I started off by scrubbing them thoroughly with traffic film remover & then 'keyed' the surface with scotch pads. They were then given a coat of primer followed by two-pack base coat & lacquer. The colour is actually Hyundai "Poppy Red". The new decals were applied prior to lacquer going on.
Hey Pete, do you fancy coming down to Richmond and doing that to mine?! My calipers are black, but I quite fancy having them in Tart Red to match the tarty red of my Coupe
Nice work though.
How the lacquer stands high temp ? As i've paited my calipers red , but didn't use the lacquer , was afraid it will crack on high temps.
Or is it special lacquier ?
It's just ordinary 2-pack lacquer Vadim. Hopefully it won't crack. My mate thinks it will be OK.
Nice work though.
Cheers Dan & Beetie. It's the prep work which takes the time. If you want your's doing I would suggest doing this yourself, i.e. cleaning, flattening & keying surface. Then getting one of these mobile paint repairers to come round & do the spraying. It probably took about an hour to do each one.
Originally posted by Beetie
Is this after we butchered them up at the garage meet?!
LOL - No mate they were fooked anyway. As you can see in the first pic the lacquer was peeling off all over.
