Alex
I'm not actually using those discs they fit on the hub ok but the caliper is about 5mm to far back for them to fit i need to take of the adapter and place a spacer in between the adapter and the hub and all will be ok only trouble is the bolts are stuck fast and i have tried every thing but no joy. I have a8 discs on the car never had trouble with noise before and it starts as soon as you pull off and its quite loud
