Hyraulic servo bleeding/priming.
  • John.
    • 2615
    I've replaced the hydraulic servo with a (supposedly good) used one, after topping up the reservoir with some green fluid I started the engine and worked the steering from lock to lock.....all good with the PAS.
    But the brake warning symbol shows if I pump the brake. Do I need to bleed fluid from both pipes going to the servo......is this done in a similar way to bleeding the brakes, do I have someone press the pedal while pipe's are loosened??
    .....anyone?
    Thanks in advance.
  • Mikes2
    • 1704
    When I last replaced a hydraulic servo, it took about 50-60 pumps of the pedal to get the light off with the engine running.
    This was on a quattro turbo but should be similar.
    Mike
    http://www.s2-audi.co.uk
    • John.
      • 2615
      Ok thanks Mike.
      • Bowie69
        • Nov 2013
        • 2675
        Also check brake fluid level is OK, as a pump can be enough to trigger the switch if the fluid level is marginal, same for the PAS reservoir.
        In other words, don't just assume it is the servo switch
        • John.
          • 2615
          ok thanks.
          So the brass thing is a switch?!
          • Mikes2
            • 1704
            Did you swap the switch over from your old one ?
            Mike
            • John.
              • 2615
              No I didn't........think I will now!
              • Dynasty
                • Jan 2015
                • 79
                • Country: Norway
                Try to disconnect the pressure switch and see if the alarm disappears...
