A good friend of mine has donated a set of s3 calipers to the avant project . They are to suit the 312mm setup in the s3. But what I need to know is what model s6 ran the 314mm discs. Motor factors here are not very helpful when it's not straight forward
Thanks in advance
Derek
A6 04-11 model disc is pretty close being 314 diameter and 59.4 hat height as opposed to 57 hat height for the standard S2 disc, will fit with 2mm spacers between S3 carrier and mounting on strutt.
