squeaking noise
  • stevieyid
    • Apr 2005
    • 2251
    squeaking noise
    hi i get a squeaking noise at low speeds not the same noise i get at high speeds i have posted in another forum. It goes away the faster u get but when crawling in traffic it comes back. Also it goes away when braking. Could it be the pads rubbing the disc slightly
  • nick92S2
    • 56
    Mine does this as well on the front off side especially when cornering at low speeds - could it be the wheel bearing???
    • Efini
      • 154
      • Home: United Kingdom Current: United States
      I have the same noise, from the rear left wheel.
      Starting to get veeeeery anoying.
