Splash guards? Brake shields?
  • Henka
    • 585
    • Home: Sweden
    You know the sheet metal thingy's behind the discs - splash guards or brake shields or what ever they are called. Do you really need them? When converting to big brakes - what do you do then? Do the A8 shields bolt up to the S2 uprights?
  • rotoryboy
    • May 2004
    • 3281
    You can get the RS2 ones which are really small then get the deflectors that clip to the wishbone (Porsche I think)
    Mark
    Race Clio RS197
    S2 Coupe ABY (Green) - RIP
    S2 Coupe ABY (Blue) - Sold
    • 90quattrocoupe
      • Nov 2003
      • 771
      Henka,
      I figured it couldn't hurt to have them on the car. I trimmed the existing shields to fit the 996 calipers. Just used a pair of tin snipes, filed the rough edges, and repainted the shield. It was rusty and needed it anyway.
      • Mikes2
        • 1704
        I just bent it back slightly to clear the disc. Make sure it doesn't foul on the ball joint at the bottom
        Mike
        http://www.s2-audi.co.uk
        • audiman
          • 4827
          I threw mine away as they had rotted away nearly. I do have 2 brand new ones sitting at work. 25 quid each or something IIRC. Think that the RS2 scope things might be a good idea tho.
          8A0 615 335 is the left one
          8A0 615 336 is the right one
          about 11 quid each or so
          Tom C - www.rcmr.co.uk
          Audi UR Quattro
          Audi 100 C3 2.0 5 cyl 115ps
          Audi B5 RS4 645ps 911nm
            Those things are the work of the devil - I hate them... Used to get stone chips wedged between the shield and the disc on some gravely B-roads here.
