RS2 brakes compatible with S2?
  • andys2
    • Dec 2003
    • 61
    Hi Guys,
    Can someone tell me if the RS2 brakes setup will fit on the 3B S2, these include RS2 calipers, Discs...is there anything else i need to make sure of?
  • dan_b
    • Sep 2003
    • 3670
    There's a wealth of info here about brake upgrades, worth doing a few hours of reading as there are quite a few things to think about. In short though, basically yes, except the genuine RS2 discs use the Porsche hub pattern, which is different to the Audi one on the S2, so you have to investigate different disc options, eg. the disc from the Audi A8...
    Well worth doing though, the improvement in braking performance from upgrading the fronts is significant.
